Cannot login into the modem KPN Box 12b
  • February 21, 2024
  • 2235 keer bekeken
i have tried everything looked at every other forum tried every link every browser i can't login into the modem. what could be the reason i saw with older boxes there was a password issue aswell and there are alot of people with the same issue on the forum. what is the issue. and all this after kpn could not identify that the internet was not activated at our adress that caused us to have no internet.
Hello @Arend.ayl, welcome.
I understand you have trouble logging into the KPN Box 12.
  1. Open the browser and go to 192.168.2.254 or mijnmodem.kpn.
  2. The username is ‘admin’. You can find the password on the sticker on the back of the KPN Box 12.
  3. After you log in, change your password to a new one.
Have you forgotten your password? Reset your router to get the password back to the password on the sticker.
Your browser might give you a security warning. You can click ‘Advanced/Geavanceerd’ to accept these risk without any problems. It's safe because you're staying within your own network. After this, you'll be redirected to http://mijnmodem.kpn.
Do you keep getting the security warning? Or does it keep saying the password is wrong? Then please, check the following:
  • Check the password. Some characters look like each other, for example the letter o and the number 0. Also, if you have a ^ in your password, then don't forget to press [space] before continuing.
  • Check if you're using http://, without the s.
  • Delete the cookies en empty the cache.
  • Don't use a VPN.
  • Use the KPN DNS.
Still no success? Then try a different browser or try http://192.168.2.254/2.0/gui/#/login.
Denise van KPN
  • February 23, 2024
  • Don't use a VPN.
  • Use the KPN DNS.
  • March 6, 2024
no afcourse it did not work i have tried everything like i said every method you can find my admin password goes like this ***
Admin: deleted password for privacy reasons
Denise van KPN
Oke, have you also tried connecting a laptop or PC directly to the modem using an ethernetcable? That way, you can change the password yourself.
