How can i get 1000mbit speed with a wired internet connection?
  • aug 12, 2024 10:14 a.m. UTC
  • 70 keer bekeken
When i connect Lan cable Cat5e to my KPN MediaBoX 12, it gives only a 100MB/S connection.
Is there a limit on the wired connection, if so how can i check and malke it 1000M/S conneciton.
2 reacties
Hi @gm.iitb . You should be able to reach 1 GBit/s with the Box 12. Have you checked the specifications of you network adapter in your system?
  • aug 13, 2024 1:37 p.m. UTC
It could also be that one of the eight wires in the UTP cable does not make a connection.
Please also try another cable.
