How can I set up WiFi 2.4 Ghz and 5 Ghz separately on KPN Box 12b?
  • nov 10, 2023 2:40 p.m. UTC
  • 1 reactie
  • 385 keer bekeken
Is setting up both WiFi 2.4 Ghz and 5 Ghz separately on the same KPN Box 12b currently possible? Smart devices are not compatible
Beste antwoord door Anonymous
Hello @avlio
You can use the “Extra WiFi” function to make a separate 2.4GHz network, smart devices which have problems connecting are always 2.4GHz.
See here for the instructions if your Box 12b has older firmware:
and here if it has the new firmware which is rolled out at the moment:
1 reactie
  • nov 10, 2023 2:53 p.m. UTC
Hello @avlio
