Inloggen op Experia Box via 192.168.2.254 lukt niet door melding "Your connection is not private"
  • July 28, 2022
  • 234 keer bekeken
Ik kan niet op mijn box komen:
Dit geeft de website..
Attackers might be trying to steal your information from 192.168.2.254 (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_REVOKED
192.168.2.254 normally uses encryption to protect your information. When Chrome tried to connect to 192.168.2.254 this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be 192.168.2.254, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Chrome stopped the connection before any data was exchanged.
You cannot visit 192.168.2.254 right now because its certificate has been revoked. Network errors and attacks are usually temporary, so this page will probably work later.
Beste antwoord door HansaanZet
@Jos van de Sanden En via deze My Modem (mijnmodem.kpn) ook niet ?
2 reacties
  • July 28, 2022
Ik heb het probleem al opgelost. Ternminsten alles werkt weer.
Bedankt voor je reactie…
Gr.
Jos
