KPN Box 12 Lan2, Lan3 and Lan4 do NOT work
  • okt 12, 2023 5:20 p.m. UTC
  • 297 keer bekeken
Mihnea Saila
Nieuwkomer
To whom it may concern,
First of all, I am sorry that I do not write this in Dutch, but I do not have enough knowledge of the language to ask these kind of questions. I will do my best to achieve it in the future!
As the title suggests, I have problems connecting via ethernet to the LAN ports 2, 3 and 4 on the KPN Box 12. I got my internet connection in the house on 26th of September 2023, and the KPN Box 12 a bit earlier in 7th of August 2023. The internet connection is 1Gbit fiber optic. The Wi-Fi works just fine, on any device, as well as the LAN port 1.
I have tried the following:
  • Plugging in different cables of different categories: Cat5, Cat6 and Cat6A both crimped by myself and store bought ones. ALL the cables I tried worked on LAN 1 but not on LAN 2, 3 and 4.
  • I have tried shutting down the modem, waiting for a few minutes and turning it back on. After doing this soft reset, the ports 2,3 and 4 would briefly work , but very soon the connection would drop, unwilling to come back on, until a new soft restart.
  • I  have tried several hard resets, but the ports would work again for a brief 1-2 minutes, only to drop again until a new soft or hard reset.
I fear that the modem has some hardware fault, but in any case, I would like to know if I did something wrong and if someone more knowledgeable than myself can suggest some other thing I could do.
Thank you!
Best regards,
Saila Mihnea
Beste antwoord door Mihnea Saila
Hi @VwDt and @Liesbeth_
I have tried before asking to hard reset the modem a few times, it did reset the modem’s settings back to the defaults but the problem persisted.
However after your reply I tried once again by unplugging every cable from the modem leaving only the power on, exactly as you mentioned.
Apparently, in my previous attempts I did not do the reset correctly, because this time I held the reset button pressed until the modem really did a kind of shut down and repowered itself. After reconfiguring everything it seems the ports work fine.
Thank you for your suggestions and fast responses!
You can close the ticket!
  • okt 12, 2023 5:53 p.m. UTC
Solution for the same problem:
“I did a hard reset, but I also disconnected the fiber optic cables and connections to the modem, waited for 5 minutes and then put everything back together and all the Ethernet ports work fine.”
source
Liesbeth van KPN
Hi @Mihnea Saila, welcome!
No worries about the language! It's fine to write (and reply) in English.
Can you please try the solution @VwDt advises and let us know if that worked?
Mihnea Saila
Nieuwkomer
  • okt 17, 2023 7:31 a.m. UTC
