KPN Box 12 reboots randomly
  • September 28, 2024
  • 184 keer bekeken
KPN Box 12 randomly reboots every ~15 minutes. It started about 3 weeks ago. No changes to wiring has been made. There were zero problems many months before. Should I request a replacement Box?
Beste antwoord door Noordzee
Ok @edrokov
Call with 0800-0402 for help.
  • September 29, 2024
@edrokov
Uw  vraag in het Nederlands graag.
Hallo @edrokov ,
Do a reset:
  • October 2, 2024
Hallo @edrokov ,
Do a reset:
Thank you for the suggestion but it didn’t help.
Anyone knows how to order a new KPN Box 12 (or whatever modern version)?
  • October 2, 2024
Ok @edrokov
  • October 2, 2024
Ok @edrokov
Thanks, they have concluded there is a hardware problem with optical modem, and somebody would come tomorrow for a check/replacement.
  • October 4, 2024
Ok, the final note: the technician has explained one specific KPN Box 12 batch is known for having faulty power adaptors, and my Box is from that batch. He has replaced the Box and power adaptor and everything works as it should for more than a day now.
