KPN Box Lan port doesn't support 1 Gbps?, only 100 Mbps
  • dec 1, 2022 9:35 a.m. UTC
  • 11 reacties
  • 417 keer bekeken
dharm
Deelnemer
Hi Team,
I changed my subscription from 100 mbps top 1gbps but i am not getting more than 100 mbps connected with lan port to modem .
Could you please help
Beste antwoord door RBxx
Hi @dharm
The LAN ports of the KPN Box 12 do support 1 Gbps. Check your cables. Do you use cat 5e or better?
11 reacties
RBxx
  • dec 1, 2022 9:54 a.m. UTC
Hi @dharm
dharm
Deelnemer
  • dec 1, 2022 12:13 p.m. UTC
Yes I am using Cat 5e
RBxx
  • dec 1, 2022 1:58 p.m. UTC
How did you determine the linespeed? Can you show it on a screenshot, without showing personal information like ip-address?
dharm
Deelnemer
  • dec 1, 2022 2:38 p.m. UTC
dharm
Deelnemer
  • dec 1, 2022 2:40 p.m. UTC
Modem View
RBxx
  • dec 1, 2022 2:48 p.m. UTC
Ok, that's clear. What kind of device is connected to the LAN port? It appears that this device has a network adapter which is only capable of (or set to) 100Mbps. Therefore you see the orange line.
My PC connection looks like this, with the green line showing 1 Gbps:
RBxx
  • dec 2, 2022 2:38 p.m. UTC
Hi @dharm , have you identified the problem?
dharm
Deelnemer
  • dec 2, 2022 10:04 p.m. UTC
I connected gigabyte router GLnet router  with lan . I was having T Mobile and used this router with 1gbps speed .
  • dec 2, 2022 11:55 p.m. UTC
Could you replace the network cable and test it again? All 4 LAN ports of your modem support 1000mb speed
Thomas van KPN
Hi @dharm, as mentioned above the modem should be able to deliver 1Gb/s fine, have you tried a different cable yet? Or perhaps a different device?
dharm
Deelnemer
  • dec 13, 2022 11:23 a.m. UTC
Hey, I did not change anything like cable or router but it is getting 1gbps . Thanks all for help and suggestions.
