Cisco 89X 15.8
VDSL (Bonded) Dialer KPN Cisco IOS
Hopelijk heeft iemand hier wat aan, de Dialer is ook voor PPPoE voor FTTH (Glasfiber)
cq:
ipv Ethernet0 gebruik je GigabitEthernet 8 of 9 (800 serie) of GigabitEthernet 0/0/0 of 0/0/1 (1100 serie).
Hier geen LAN config en FW…. Ik ga er vanuit dat als je Cisco IOS router gebruikt, je dat ondertussen al weet. Mocht iemand behoefte hebben, laat het maar weten!
Ciao
S
controller VDSL 0
operating mode vdsl2
! firmware filename flash:VA_A_39h_B_38h3_24h_j.bin WERKT OOK MET EMBEDDED FW
! line-mode bonding ALLEEN 897VAB
sync mode itu
sra
interface Ethernet0
mtu 1512
no ip address
interface Ethernet0.6
encapsulation dot1Q 6
pppoe enable group global
pppoe-client dial-pool-number 1
pppoe-client ppp-max-payload 1500
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer-group 1
no cdp enable
ipv6 address 2A02:A4XXX:XXXX:0:b19:ba11:c001:b00b/64
ipv6 enable
ipv6 nd ra interval 30
ipv6 verify unicast reverse-path
ipv6 dhcp client pd hint 2A02:AXXX:XXXX::/48
ipv6 dhcp client pd kpn-dsl-prefix rapid-commit
ipv6 mld query-interval 60
ipv6 virtual-reassembly in
ppp authentication pap callin
ppp pap sent-username kpn password 7 07043142
ppp ipcp dns request
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ip route 0.0.0.0 0.0.0.0 Dialer1
ipv6 route ::/0 Dialer1
ipv6 ioam timestamp
c897vam#ping 1.1.1.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
c897vam#ping ipv6.google.com
Sending 5, 100-byte ICMP Echos to 2A00:1450:400E:810::200E, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
c897vam#
