No physical Ethernet link on the optical box
  • December 13, 2022
  • 12 reacties
  • 665 keer bekeken
Hello,
Since Sunday night, I have no Internet. Basic troubleshooting displayed that there is no link on the bottom Ethernet port of the PON box that goes to the WAN port of the KPN Box 12.
The LEDs state:
  • Optical box:
    • Power: solid green
    • Connection: solid green
  • modem:
    • Internet: blinking green
    • WiFi: slowly blinking green
In the modem Web UI → My modem → General
Network
Local IPv4 Address 192.168.2.254
Local Subnet Mask 255.255.255.0
Local Ethernet Mac address 6C:99:61:E9:ED:97
Public IPv4 Address -
Public Subnet Mask -
IPv4 Online Duration 00h00m00s
Default Gateway -
Primary DNS Server -
Secondary DNS Server -
Delegated Prefix -
Link Local Gateway IPv6 Address -
Global Gateway IPv6 Address -
Default Gateway IPv6 Address -
IP Version IPv4/IPv6
Ethernet WAN
Status Disconnected
Connection Time 00h00m00s
Bitrate 0
In the modem Web UI → My modem → Statistics:
WAN Layer 1 - Ethernet
Status Dormant
  Received Sent
Packets 0 0
Bytes 0,00 0,00
Errors 0 0
Drops 0 0
Pictures to illustrate:
WAN port LEDs are off
Both power and Connection LEDs on the PON box are solid green
No light on the Ethernet port of the PON box
Front LEDs of the modem; Interned LED is blinking
Steps I have already done:
  1. Reset the modem - soft reset (power off and on)
  2. Reset the modem - hard reset - twice (restored factory settings from the UI; additionally pushed the tiny button until the lights went off, as asked by the technician on call).
  3. Soft-reset the PON box (power off and on)
  4. Re-seat the PON box physically
  5. Plugged one of my computers to the WAN port of the modem: LEDs on the WAN ports went on. The WAN port of the router is not dead.
  6. Plugged RJ45 of the PON box to the other LAN port of the router: no link
  7. Plugged RJ45 of the PON box to a computer directly: no link
Steps 5-7 done both with the cable provided during the installation months ago and with a brand new tested Cat 6e patch-cord.
From what I see, this looks like the PON box malfunction
I tried calling the Support where we performed all the above once again with no progress. The man I talked to offered me mobile traffic which is helpful to stay connected but definitely is not fair replacement of 1 Gbit connection I used to use.
Please let me know what would be the next steps to resolve the issue and restore the connectivity between the PON box and the modem. Thanks.
Beste antwoord door wjb
This is a typical problem of the XGS-PON ONT that was disconnected from the power. A bug in the firmware sometimes causes the Ethernet port to fail in such cases. There has been a firmware update lately that solves this issue but it seems your XGS-PON ONT did not receive that firmware yet.
Your XGS-PON ONT needs to be replaced.
Please call customer service at 0800-0402 and ask for a replacement of your ONT.
12 reacties
  • December 13, 2022
Bart van KPN
  • December 13, 2022
Hi @skv25, welcome.
Everything looks fine, but no internet. Even after all your possible solutions you have tried.
What wjb told you is exactly what I thought. So the fastest way for contact is calling 0800-0402.
If you prefer this way, please fill in your profile and let me know when you did. I will look into it.
  • December 13, 2022
Hello @Bart_Z
Thank you the prompt reply. My profile is now populated, please check if you have everything required from my side. Thank you.
  • December 13, 2022
Hi @wjb,
I appreciate your answer.  I assume I cannot update the firmware at home, and moreover the PON device is probably bricked. Hopefully, @Bart_Z will arrange RMA.
Bart van KPN
  • December 13, 2022
I got everything I need. I have notified my expert colleagues. They will call you to handle it further.
  • December 13, 2022
Thank you @Bart_Z, I’ve received an SMS that KPN is aware of the issue. I’ll wait for a call to have our next steps explained.
Bart van KPN
  • December 14, 2022
A mechanic needs to scheduled by my colleague to replace the ONT. Please let me know when that happened.
  • December 14, 2022
Good morning @Bart_Z,
Thanks you for your message. I haven’t been contacted by phone yet. For me, any day and time will be good for the technician visit. I work from home and am always available. Thanks.
  • December 14, 2022
To update and close the thread.
The KPN representative called me and offered a very convenient time slot for the technician visit.
The technician have done the job quickly, and I’m back online.
Thank you @Bart_Z, I appreciate your and your colleagues’ effort in solving this problem.
Bart van KPN
  • December 15, 2022
Nice to hear! You are very welcome!
  • January 20, 2023
Don’t want to hijack this topic, but I have exactly the same issue.
Kan iemand van KPN helpen?
Bedankt!
  • January 20, 2023
Bedankt!
Niet meer nodig gelukkig.
Er kon vandaag gelijk een monteur ingepland worden en die heeft direct de XGS-PON vervangen en dat was bij mij ook de oplossing.
