Ordering new Box 12 to replace current broken one
  • February 10, 2023
  • 138 keer bekeken
Dear KPN,
I would like to order a new modem (I think my current one is box 12).
My current one is broken due to a water leakage to my power distribution room.
I would like to know how to order/arrange that.
Thank you!
Beste antwoord door Anonymous
Hello @Raijmond110
Quickest way to get a new modem is to call Customer Service on 0800-0402, you will get some options in dutch, just ignore that and say you want to speak to an employee.
  • February 11, 2023
Hello @Raijmond110
Last time you had support from KPN, a mechanic fixed your fiber optic box. Ans now youre Box 12 is broken? Some really bad luck!
You still need support? Or did the customer service help you to get a new Box 12?
  • February 21, 2023
Hi @GeSp and @Jeroen_dB ,
Yes the issue is resolved, new modem was delivered and old one was returned.
Thank you both very much for your support!
