Port forwarding KPN Box 12 doesn't seem to work
  • August 16, 2024
  • 1 reactie
  • 93 keer bekeken
Hello,
Trying to do a portforwading config on my KPN Box 12 router and I did add it to the list, pointed it too my server running on port 8080 and gave it a local port 9002. But when trying to access that server via my public_ip:port I don’t succeed. Does someone know if there is a problem? Blocker maybe?
Thanks.
Beste antwoord door bnh
Can you check here the status ?
https://www.yougetsignal.com/tools/open-ports/
Maybe post some screenshot from your box 12 settings.
1 reactie
bnh
Forum|alt.badge.img+12
  • August 16, 2024
