Setting a costum DNS server with Experia Box V10A doesn't save
  • jun 15, 2023 4:21 p.m. UTC
  • 98 keer bekeken
After typing in the address of the DNS server and clicking save, the router still doesn’t use it. Do I need to change the settings anywhere else?
Beste antwoord door Anonymous
Hi @yoav
By now your devices should have renewed their DHCP leases, if the Lease Time is One Day like in your picture then they renew after half a day.
You can also do it by restarting the devices.
  • jun 15, 2023 5:05 p.m. UTC
Hello @yoav
Did you renew the DHCP Lease on the device(s) after you changed the DNS and saved it?
Without doing that your device(s) keep using the old DNS setting until it renews it DHCP Lease automatiscally.
  • jun 16, 2023 9:53 a.m. UTC
Hi @GeSp!
I restarted the router which didn’t work. Is there a way to renew the DHCP leases for all connected devices?
  • jun 16, 2023 10:05 a.m. UTC
Hi @yoav
