After typing in the address of the DNS server and clicking save, the router still doesn’t use it. Do I need to change the settings anywhere else?
Hello @yoav
Did you renew the DHCP Lease on the device(s) after you changed the DNS and saved it?
Without doing that your device(s) keep using the old DNS setting until it renews it DHCP Lease automatiscally.
Hi @GeSp!
I restarted the router which didn’t work. Is there a way to renew the DHCP leases for all connected devices?
Hi @yoav
By now your devices should have renewed their DHCP leases, if the Lease Time is One Day like in your picture then they renew after half a day.
You can also do it by restarting the devices.
