Activation KPN Prepaid Card in Germany
  • December 5, 2022
  • 105 keer bekeken
Hello,
How can I activate a KPN Prepaid Card, which I have bought last week in the Netherlands, in Germany? Anyone from KPN who could help with this? Thank you!
Best regards
Beste antwoord door RBxx
Hi @Carand71
You can only activate a prepaid SIM card yourself if you are in the Netherlands and directly connected to the KPN network. A KPN moderator can do this "remotely" for you.
Put the 06 number and SIM card number in your forum profile (click here). Use the "Persoonlijke opmerkingen" field, which is only visible to you and KPN employees. Save your input by pressing Sla wijzigingen op at the bottom of the page.
Leave a message here if you have done so, I can notify the moderators.
RBxx
  • December 5, 2022
Hi @Carand71
  • December 5, 2022
Thank you for the quick response! I have left the information in the "Persoonlijke opmerkingen" field in my forum profile.
Best regards
Hello @Carand71, i have just activated your Prepaid simcard.
RBxx
  • December 5, 2022
Kijk eens aan, dat is samenwerken. 😉
