I can't call international in EU countries with my prepaid
  • jan 2, 2025 8:57 a.m. UTC
  • 109 keer bekeken
Hello! I can't call in any Eu countries. I have this problem since I got the sim. Please help me to solve this issue. Thank you!
Forum|alt.badge.img+3
Put your KPN Prepaid phone number and sim card number in PRIVATE fields of your community profile, so a KPN moderator can check the sim's activation status.
See https://community.kpn.com/settings/profile .
Hi ​@Laura Dinulescu .  Welcome to the KPN Community.
Where did you buy the SIM card? Have you tried rebooting your phone?
Hi! I have the SIM card for almost 2 years, and I didn't change my phone. It works perfectly fine unless if I try to call to any other country. I tried to call in Romania, Germany.
Over the past two years, I have tried all the settings, rebooting, etc. and nothing worked.
Thank you!
  • jan 13, 2025 10:26 a.m. UTC
Hi, ​@Laura Dinulescu .  since it's prepaid i don't have much options on my side.
I recommend visiting a KPN store to explain your issue. They should be able to assist you. For a smoother experience, consider going on a weekday rather than the weekend to avoid long waiting times.
Best of luck!
