I can't call or text to other EU countries
  • jul 2, 2022 5:59 p.m. UTC
  • 12 reacties
  • 669 keer bekeken
Hello,
I have a prepaid KPN sim, and I am unable to call/text outside of Netherlands to other EU countries.
I have 18€ Credit, which says can be used "throughout EU". I also have an additional 60 minute bundle which should also work in EU. I obviously use country codes. I tried several countries, it doesn't work.
Any help will be appreciated
Best
Michal
12 reacties
Forum|alt.badge.img+28
  • jul 2, 2022 6:28 p.m. UTC
Hi @Michal28, welcome on our board.
I'm glad to help. Are you able to receive calls? Also, are you getting an error message when trying to call someone?
  • jul 3, 2022 1:17 p.m. UTC
Thank you Alex,
Yes, I can receive calls/texts from other countries. When I try to call there's no error message, just a quick sound.
  • jul 3, 2022 2:04 p.m. UTC
Hmm,. Let me check this for you. Would you please fill in your KPN profile and let me know when it's done?
Also, do you have the country number/prefix when calling? For The Netherlands for example: 0031612345678.
  • jul 3, 2022 7:39 p.m. UTC
I filled the KPN profile. And yes, I am using country codes when calling/texting.
  • jul 4, 2022 7:53 a.m. UTC
I called support, they suggested resetting. Still no Luck.
I have Iphone 13, I've reset Network settings, I turned Airplane mode On/Off, the roaming is turned ON. I also tried on an older Iphone and it still doesn't work. At the same time an international sim card (from Poland) works normally, it actually connects to KPN network.
  • jul 4, 2022 10:24 a.m. UTC
One more detail, when I was in Belgium a week ago, I was able to text a Belgian number at least once. Now that I'm in Netherlands I cant text to it anymore.
  • jul 6, 2022 11:49 a.m. UTC
Would you please try this again in about 10 minutes?
  • jul 6, 2022 2:29 p.m. UTC
I got messages from KPN that my settings are being changed. However, the problem persists .. I reset it, turned airplane mode on/off as before .. I still get the busy signal when calling abroad and can't text
  • jul 6, 2022 3:13 p.m. UTC
This is so weird. Do you by any chance have a KPN shop around? Another option is to order a new simcard with the same number and credit. You can order a new here by entering your phone number en sim number. This will cost you € 5.- and will be paid from your credit. I can reimborse this amount.
  • jul 6, 2022 3:22 p.m. UTC
Yes, let's order a new SIM card then. Where should I enter the details?
  • jul 6, 2022 3:48 p.m. UTC
I'm sorry, I forgot the link. You can exchange the prepaid simkaart by clicking on the link. I also added € 5.- credit to your number. Let's hope this will solve the problem.
  • jul 6, 2022 4:09 p.m. UTC
Thank you Alex!
