I cannot activate my SIM card
  • September 10, 2023
  • 173 keer bekeken
Hi there. I bought a SIM card last week, and I wanted to activate but I cannot. I m currently aborad, can anyone help me how to activate the card? Thanks
Hi @karampula, welcome on our forum.
It's done, would and could you please confirm this?
RBxx
Hi @karampula
You cannot do this yourself. That only works when you are in the Netherlands, connected directly to the KPN network.
Put the phonenummer (06xxxxxxxx) and the SIM cardnumber (iccid) in your forumprofile.
Use the field "Persoonlijke opmerkingen” (only visible for you and KPN) and save your input by pressing “Sla wijzigingen op” at the bottom of the page.
Report back here when you have done this, then a moderator can activate the SIM card for you.
Thank you very much for your answer.
I updated the numbers as you asked.
RBxx
I’ve brought this to the attention of the moderators.
Forum|alt.badge.img+28
it works now, thank you so much for your help :)
You're very welcome, I'm glad it's working now.
