Impossible to make calls with my prepaid simcard
  • June 24, 2024
  • 67 keer bekeken
I have a prepaid sim card that I bought a few weeks ago. Initially I was able to make calls, but now it has been blocked. I’ve switched my device on and off. Its also not in airplane mode.
The internet works fine.
Does someone have a solution to this?
Welcome to the community @Christiaan12345. Like Peter I'm also curious how you use the internet connection. If it is via Wifi, it is not related to your prepaid credit. How exactly is it blocked? Did you get a message telling you it is blocked, or has something else happened?
Have you called *101# yet? That way you can see the remaining credit. If there is none, you're not blocked, you just need to top it up.
2 reacties
  • June 24, 2024
Did you already enter beltegoed on the number?
Via 4G? Internet via wifi doesn't require a simcard at all.
