Antwoord
Prepaid card not activating
  • March 10, 2022
  • 48 keer bekeken
Prepaid card not working
Hello @robert3892
Hi @robert3892
Where are you? A prepaid simcard is activated in the Netherlands by connecting to the KPN network and making one (short) phonecall. Outside the Netherlands this doesn’t work, then you’ll need help from a KPN moderator. Place the 06-number and simcardnumber in your Forum profile . Use the field “Persoonlijke opmerkingen” for that. Then they can activate the simcard for you.
If you do that, i can help you!
2 reacties
RBxx
  • March 10, 2022
Hi @robert3892
  • March 10, 2022
Hello @robert3892
Hi @robert3892
