Trying to activate the buitenland bundel
  • September 26, 2021
  • 9 reacties
  • 125 keer bekeken
Hi,
I’ve a prepaid number and trying to activate the  buitenland service (since I’m not in NL right now) but the site won’t load the my settings.
I keep getting a No Service message and therefore, cannot activate the KPN app either.
Best regards,
Anibal
9 reacties
Forum|alt.badge.img+28
Hi Anibal, welcome on our board.
Let me check this for you, would you please fill in your profile? Let me know when it's done.
Hi @Alex_P,
I’ve filled in the details. Most important is the phone number, I guess.
thanks for the quick response,
Anibal
Everything is fine here, it should work. Did you try to connect with a a different network there? Also, in which country are you right now?
RBxx
removed. message not relevant.
I did. Tried all sorts of networks.
if everything is well set, then it could be a local issue with foreign SIM cards.
is there any way to activate the KPN App without SMS verification? Even whatsapp would be ok, but not SMS since I get no service
Ni. I'm afraid not. But that is not the problem, the problem is that your phone does not connect with a network. Is the roaming option on your phone on?
  • September 29, 2021
Yes sir, it is.
I’ve even tried putting the sim card into another (local) phone and the result is the same: no service.
Roaming on/off, data package on/off, manual provider/automatic provider, different phones. All these I’ve tried :disappointed:
I'm lost. My guess is that it's local problem. :pensive:
  • September 30, 2021
Most likely but please, don’t get frustrated. I really appreciate the help.
I shall take my sim to a local phone shop (most of them had no idea) and try to figure out what the issue is.
Thanks again for the assistance. :pray_tone1:
