office phone > personal mobile phone does not not connected every calls
  • March 23, 2020
  • 1 reactie
  • 115 keer bekeken
Due to coronavirus measures, we have transferred office phone (020-***) to staff personal mobile phone (...) and call center in Korea during lunch time and 17:00~09:00 (+82 800-***)
The main problem is that not all incoming calls are not received/connected.
We have tested 3 times on last Friday (20 March) as follows:
- Call to the office (***) 2 times around 12:28
- Those 2 times of calling were NOT connected and hear automatic voice mail as attached (Dit nummer is niet in gebruik)
- 3rd call is connected well.
The other issue is to check the possibility to switch off *** on forwarding number of 9 lines (020-***) for temporarily period of 1 month.
So that the caller ID is shown when the phone is forward to personal mobile. Only 020-*** is shown when you are calling from all 9 lines.
  +31-(0)20-*** is valid or not ?
    => Can you check if this number is valid when I called from my mobile to ***
         ARS : This number is not reachable, try it later. (and automatically hung up)
Admin: personal information and phone numbers removed for privacy reasons
Hello @Korean Air, welcome to our forum. Unfortunately I'm going to have to redirect straight away. You are a business, and this is the consumer forum for KPN. And, in addition, as I see this involves ISDN/PSTN. Which means that we, unfortunately, cannot help you.
Depending on what kind of contract you have with us use one of the following means of contact: If you fall under what we call ‘grootzakelijk’ you can call 0800-1576, be advised you need the supplied pin code to use this number. If you fall under another form of contract, you can call 0800-0403.
1 reactie
