Apparatuur teruggestuurd, komt het goed aan?
  • feb. 16, 2023 1:21 p.m. UTC
  • 1 reactie
  • 17 keer bekeken
So I send my return box on the 21st January and it arrived at your return centre on the 24th January 3SLFVZ256115829 on postnl. since you sent me the box without paperwork, i sent you the box to the address provided on your webpage under “if you didn't receive the box, please send it to us to the address
ANTWOORDNUMMER 10119
2400VB ALPHEN AAN DEN RIJN
However, today 16th February i got an email from you stating “we haven't received anything from you”. Please, with the code above, see if you can find it in your premises. Thanks, Rita
1 reactie
Forum|alt.badge.img+28
  • feb. 19, 2023 12:33 p.m. UTC
Hi @RitaFaria, welcome on our forum.
I'll gladly check this for you? Would you please fill in your KPN profile and let me know when it's done? Also, which box(es) did you send?
