192.168.2.254 inloggen lukt niet
  • February 2, 2020
  • 752 keer bekeken
I was able to login once. could not get the password right and after 5 attempts it was shut off.
I bought the system back-up (reset of both the network modem and the router (heb glazvezel) maar kan nu niet meer inloggen op mijn experia box  Can’t find page. My main internet cannot connect to while my guest interenet is again working. What is going on?
Hi @A3A, I understand you're facing some difficulties with your wifi/Experia Box but I'm not sure what those difficulties are at the moment. Can't you reach the login page of the Experia Box any more? Or can you reach 192.168.2.2.54 but logging in doesn't work? Or is logging in the menu not the issue and can't you connect to your main wifi network?
2 reacties
Maja van KPN
  • February 5, 2020
Maja van KPN
  • February 10, 2020
Hi @A3A, I haven't heard from you, so I'm hoping you were able to fix your issues. If not, please let me know!
