4 pin plug missing and dsl cable are missing in our new house
  • September 13, 2021
  • 170 keer bekeken
My family and I just moved into a new house and am setting up our home router. The router uses dsl and the house connects through a 4 pin plug. However we do not have the 4 pin plug or the dsl cable. Where might i find these on the market.
Beste antwoord door Ward_
Any DIY store. Gamma, Praxis, etc..
Forum|alt.badge.img+12
  • KPN Netwerk
  • September 14, 2021
Pleas check if you really connect to te ISRA point and not a telephone connection point.
If it is the a connection point like the left one in the image above it could be that the ISRA point is somewhere else.
Hi @4 pin connector missing, welcome to our forum. As Ward_ said, you can purchase these cables at any DIY store. Did you manage to find them? Have you also checked wjb's suggestion, is the socket you're planning to use the main connector (the IS/RA)?
