Change of place of residence. Can I move my connection?
  • October 5, 2020
  • 10 reacties
  • 775 keer bekeken
Can you bring the Internet with you to your new apartment?
Beste antwoord door Demidoff
Alex_P  and Zeonz
Thank you for answering the topic. According to the link that the moderator gave a link(to inform about the move) wrote there on the 26th, I will choose. I'm waiting now when they make the Internet.
THANKS AGAIN FOR THE ANSWERS !!!!!!
10 reacties
Forum|alt.badge.img+27
  • October 10, 2020
Hi @Demidoff, welcome on our board.
That depends, what does this site say when entering your new postal code and house number? You will also need to let us know that you’re moving and when you will be moving to your new address.
  • October 10, 2020
Moved a week ago, at that address, repairs will be done, I think for a long time. Now address is ********
As I understand it, you can transfer.
  • October 10, 2020
Yes, I can see that it's possible. Did you already let us know?
  • October 10, 2020
Yes, I did!
  • October 10, 2020
I think what Alex_P here means is, did you already contact KPN (outside of this forum) to let them know that you we're moving and that would like to move you're connection to the new address? And if so, did you get a confirmation through mail that you we’re gonna move and that you're new connection will be transferred to you're new address?
I'm not certain if the moderator's on this forum can input this change for you. Also please remove you're address from the forum post (you can add this into you're profile, those with "Privé” next to them are only visible to the moderator's of this forum). Since this is a public forum anyone on this forum can now see you're address, and I doubt that's what you want.
  • October 10, 2020
Yes. And we can't, but he can do it himself here as mentioned above. :relaxed:
  • October 10, 2020
Alex_P  and Zeonz
  • October 10, 2020
Alex_P  and Zeonz
You're welcome, let me know if I can help with anything in the future.
  • October 10, 2020
Alex_P
The only question. If I chose the move date October 26th. Will the installer come to me on the same day?
  • October 11, 2020
Usually yes, otherwise we will let you know. Be sure to check the confirmation after entering the move.
