Connection slot A is broken, how to fix it?
  • aug 31, 2026 5:28 p.m. UTC
  • 136 keer bekeken
The connection point slot A is broken..It seems that the previous owner put a glue on the port thats why when I pull out the device the cable broke..is it possible to use the slot B?
Beste antwoord door Bastiaan Sahetapy
Hi,
Give us a call on 0800-0402, they will sent someone out to fix it for you! We don’t use the B side on the FTU, so the technician will probably replace the whole ftu!
7 reacties
Maikel Drost
  • aug 31, 2026 5:56 p.m. UTC
Can you take a picture? Maybe we can help you. If it really is broken, a technician will have to come out anyway.
  • aug 31, 2026 6:02 p.m. UTC
Bastiaan Sahetapy
Forum|alt.badge.img+7
Hi,
Forum|alt.badge.img+4
  • Medewerker KPN Escalaties
  • aug 31, 2026 7:52 p.m. UTC
Indeed, the B side of the fibre cable is cut diagonally, while the A side is cut horizontally. Most providers use the A connection. There are providers that use the B connection as well, although I have never actually seen one myself. But that is the technical explanation.
If you are already a customer and your order has been completed, call KPN and request a technician. They can either fix the issue themselves or create a ticket for the network department so it can be repaired.
If you are a customer but your initial order still has to be completed, you can add a technician to the order, or wait until the order has been completed and then request one.
If you are not a customer, the fibre connection will not be repaired. You need to have an active service. This does not necessarily have to be with KPN, but it must be a provider that uses KPN's fibre network.
  • sep 4, 2026 11:52 a.m. UTC
Hi ​@Z.C welcome to the KPN Community. I would also like to advise you to contact us asap so an appointment with a KPN mechanic. Did you manage to contact them?
  • sep 4, 2026 11:59 a.m. UTC
Hi all,
Thank you very much for your comments and recommendations. KPN already sent a technician and fixed/replaced with a new FTU.
  • sep 7, 2026 6:39 a.m. UTC
Hi all,
That's great news! I'm glad it's fixed ​@Z.C!Â
