DVS 1200 firmware version 2.7.0.02-2
  • October 1, 2025
  • 375 keer bekeken
Hi everyone,
Here's the problem - got 3 DVS 1200 devices but as you can see only one of them has newer firmware installed. The only available version for download is the 2.4 version here.
My question is - where I can grab the 2.7 version ? thanks in advance
Hi ​@locosmike . Welcome to the KPN Community!
To get the very latest update, it’s best to use the manufacturer’s software. That is the Devolo Cockpit Software. You should be able to find it here. Install it on your PC or laptop, and then you can easily detect and update the DVS adapters in your network.
Let us know if you managed to get it working or if you still need any help.
  • October 3, 2025
Dear ​@locosmike see also this link for updates:
https://www.kpn.com/televisie/installeren/draadloze-verbindingsset?campaignid=so:c=merk-community
CC ​@Arjan van KPN
  • October 20, 2025
Hi Arjan,
Thanks for the reply !
The devolo cockpit software is up and running but when I hit the check update button I am receiving this (while my network connection is running perfectly) :
Devolo software is the latest and greatest revision.
Any advice ?
CC@Arjan of KPN
thanks for sharing the link, but it doesn’t solve my problem with lack of 2.7.0.02-2 drivers.
  • October 21, 2025
ok, so i can reply to myself as I have sent the question to Devolo support about  Devolo Cockpit software and internet connection message:
there is nothing wrong with your pc - its just Devolo who shut off the server….
Ah, it’s good to know that the update server is down on their end. That’s unfortunate, but updating via the Cockpit software won’t work then.
You can still check the link that JanD shared earlier to see if the correct update file is available there. Scroll down to “Veelgestelde vragen over de Draadloze Verbindingsset” and click on “Hoe update ik de software voor de Draadloze Verbindingsset 200+, 650 of 1200?”. There you’ll find the zip-file for your specific DVS model, which you can download and install.
