DVS 650 and 1200 combine possible?
  • January 27, 2021
  • 272 keer bekeken
Billy Yang
Deelnemer
I am using DVS650 well 3pc,
and I bought DVS1200 3pc more for extendition all together.
but that is not working together different version.
only working well when pluged in same version.
Do I need to some additional setting? to use all together at once?
Thanks.
Beste antwoord door RBxx
Hi @Billy Yang
Both models should work together, they are compatible. Try to pair them (again) by plugging them into each other, forming a ‘block’ into a wall socket. Press the “reset” buttons if necessary.
For more help see this topic: solve problems with DVS. It’s in Dutch so use Google translate.
Forum|alt.badge.img+7
  • January 28, 2021
Must be possible if same brand.
Reset them and pair them again.
RBxx
  • January 28, 2021
Hi @Billy Yang
DVS1200 and DVS650 should work together fine, although the connection speed is limited by the slowest one. You’re talking about 6 units in total, right? KPN advices to use max. 3 units in your house. Each extra unit uses part of the available bandwidth. 4 units might work, but 6 is stretching it a bit to far.
See this info: https://www.kpn.com/televisie/installeren/draadloze-verbindingsset.htm
Billy Yang
Deelnemer
  • January 28, 2021
but it is not working also:
1 dsv650  : 1 dsv1200
only two line also not working.
bit same socket warking well if both line has same verson only :(
Who did fix it in this same case? how can i reset??
RBxx
  • January 28, 2021
Hi @Billy Yang
Billy Yang
Deelnemer
  • January 28, 2021
Hi @Billy Yang
Thanks !  Successful working now!
RBxx
  • January 28, 2021
Hi @Billy Yang you're welcome, enjoy!
