Hi All,
I have a connection V10 and want to enable IPv6, can you anyone know the process?
Can i do it myself? any user guide?
Thanks a lot!!
Daljit Singh
Do you see the IPv6 settings when you login on the V10 or id IPv6 not even mentioned in the maintenance pages of the V10?
I have not tried login to modem. I just checked by opening whatsismyip.com and it showing ipv6 not detected.
Can you help me with the steps, meanwhile let me try to login to V10
Go to http://192.168.2.254 or http://mijnmodem.kpn and login.
If you have never logged in to the Experia Box then the password should still be empty.
I logged in to the box and enabled Ipv6.
It was simple, thanks for the support.
Daljit Singh.
