(English) connect network as WAN to experia box v10A
  • jan 13, 2021 1:48 p.m. UTC
  • 1 reactie
  • 117 keer bekeken
punicpunk
Nieuwkomer
Hello,
I have an experiabox V10A at home, and I am trying to connect another router as WAN to it - but it doesn’t work. i know it is not a problem with the other router as it can connect to my office network no problem, but with the experiabox the connection times out. I think it might be a dhcp issue.
Here are the system logs:
Jan 13 14:20:26 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPDISCOVER from 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:27 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPOFFER on 192.168.2.21 to 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:29 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPDISCOVER from 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:29 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPOFFER on 192.168.2.21 to 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:52 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPDISCOVER from 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:52 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPOFFER on 192.168.2.21 to 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:54 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPDISCOVER from 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:20:54 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPOFFER on 192.168.2.21 to 02:30:44:3a:80:4d (IBR200-04d) via br0
Jan 13 14:21:41 Arcadyan VRV9517 v6 daemon.info dhcpd: DHCPDISCOVER from 02:30:44:3a:80:4d (IBR200-04d) via br0
… and it continues like that for a while. The IBR200-04d is the router I am trying to connect to the experia.
Would you be able to provide any help? Thank you very much!
1 reactie
Bart_
  • jan 21, 2021 12:42 p.m. UTC
Hi @punicpunk Did you find a solution for this problem yet, or do you still need help? Perhaps @wjb could help you out, if you still need assistance?
