Experia Box V10A red light
  • May 8, 2021
  • 73 keer bekeken
Hello,
I have exactly same issue since this morning. I have tried contact KPN by phone, but no one answer. Anyone could help?
Wei
Admin: afgesplitst en eigen topic voor je aangemaakt
Beste antwoord door Weitohome
Hello,
Thanks for reply, it has solved after I submit it by your support robot dialog system.
I got a message by phone, that you solved it, then I have tried, it works.
Thanks
Marcia van KPN
Hi @Weitohome, welcome! Is the issue resolved by now? Did you get in touch with us? Is it only the red light that is present or do you really have problems with your internet/wifi? Could you please update your forum profile with your adress and customer number? We will look into it.
  • May 10, 2021
Hello,
Thanks
Bart van KPN
  • May 10, 2021
Very nice! Glad to hear to problem is already solved. :)
