Fiber activated, but no internet: Experia Box gets no connection
  • nov 6, 2026 5:09 p.m. UTC
  • 11 reacties
  • 48 keer bekeken
I am a KPN customer and I am moving from DSL to fiber. My DSL connection still works. The fiber does not work yet.
Timeline
- 5 November 2026: I received the Nokia fiber box (ONT) from KPN and connected it. The Connection light was steady, but there was no internet. I expected this, because the activation was planned for 6 November.
- 6 November 2026: I received the email that my fiber is activated. I followed the installation steps on the KPN website. The last step says: "Oeps, we zien dat je nog niet bent aangesloten. We gaan proberen je verder te helpen."
Current status of the fiber box
- Power: on
- Connection: steady
- Data: blinks now and then but mostly steady
- Alarm: off
After a restart, the Connection light first blinked very fast for a few minutes and then became steady again.
What I tried
- I connected the fiber box to the WAN port of my KPN Experia Box v10 and removed the DSL cable.
- The Experia Box detects the fiber box, but it gets no internet connection. In its status, it switches every 30 seconds between "PPP connecting" and "DHCP selecting", and it never gets an IP address.
- I restarted the fiber box and the Experia Box, more than once and at different times during the day. Nothing changed.
- I checked the cables. The fiber cable is clicked in.
- When I connect the DSL cable again, the Experia Box goes back to DSL and the internet works.
I could not reach customer service by phone, and the activation email is from a noreply address.
Question: can a moderator please check whether the internet service is set up on my fiber line and on this fiber box?
Thank you!
Beste antwoord door cornball1698
A quick update: I had scheduled an engineer visit for mid-December, but yesterday, out of curiosity, I decided to connect the experiabox to the ONT once again. To my surprise, it connected to the internet within a few seconds!
So, it seems the problem was not with my setup or equipment after all, but rather something on KPN's side.
I'm glad it's finally working, but I do wish customer support had been able to identify and resolve the issue during my first call. It would have saved quite a bit of time and frustration.
Anyway, thanks again to everyone in this community who took the time to help!
11 reacties
  • nov 7, 2026 8:43 a.m. UTC
Ze zijn gewoon te bereiken hoor.
Heb je de ONT al eens van de stroom afgehaald voor een paar tellen?
huistijger
  • nov 7, 2026 8:46 a.m. UTC
Hi ​@cornball1698
You can make a calling-appointment , and KPN will call you at a time that suits you.
Or call KPN's toll-free number 0800 0402.
Available: Mon-Fri 8:00 AM - 6:00 PM, Sat 8:00 AM - 5:00 PM.
Closed on Sundays and public holidays.
  • nov 7, 2026 1:20 p.m. UTC
I restarted the ONT several times, also with the power off for some seconds.
I also had a call with customer service (thanks to huistijger). We spent about 25 minutes on the problem and tried a second ethernet cable, but the call ended with no solution and no next step, and nobody called back afterward.
The modem also got a factory reset.
With the ONT (Nokia XGS-PON) connected to the modem, the modem's services light is orange and its internet light blinks.
My DSL still works for now, but I do not know for how long.
Can a moderator please check if internet service is set up on my line and my ONT, and give me a case number? If nobody can fix this, I think I have to return the fiber equipment and stay on DSL until the end of my contract.
huistijger
  • nov 7, 2026 3:08 p.m. UTC
You have to call 0800 0402 or make a calling-appointment
Forum|alt.badge.img+4
  • Medewerker KPN Escalaties
  • nov 7, 2026 4:46 p.m. UTC
If the connection led is lighting up constantly and the wish date has arived (should have an email with message you can start using your connection) then you can start using it. If it doesn't work you then can order an engineer to check to connection/install your connection on fiber. Also possible is to check with an customer support agent if it can be resolved without an engineer. If you already did this then I suggest ordering the “installatie garantie monteur” (engineer)
  • nov 7, 2026 11:52 p.m. UTC
Thank you all for your help, and thank you ​@Sacratus1977 for the advice.
I checked the engineer option earlier. Based on my schedule and the available slots, the first visit I can get is in mid December. By then my return period will be over, and I could simply stay on DSL. But I would honestly prefer not to wait that long! So I am trying to find the cause myself, with my limited knowledge, some help from AI, and the information and help in this community. I see that some of you work at KPN, so I hope you can help me check things that only KPN can see.
What happened with customer service
On 7 November around noon I schedule a call with customer service. I explained the problem, and we tested many things on my side, and I think also on their side. We tried a brand new Ethernet cable between the ONT and the WAN port of the modem, but nothing changed.
Then the employee asked me to do a factory reset of the modem. I pushed a pin into the reset hole and waited for the modem to start again. That did not help. Later, the employee asked me to press and hold the "Herstel" button on the modem for 4 seconds. we waited for a few minutes and the model behaved the same, during that, the employee was mostly silent, and then the call dropped. Nobody called me back.
Because of the factory reset, I then had to set up DSL and all my modem settings again, so that my devices had internet. After that, I turned off the ONT. Later that evening I turned it on again for one more try.
When I work from home, it is difficult for me to call during working days and be offline for an hour or more. That is why I am asking for help here first.
What I observed
  • After I turned on the ONT, the Connection light repeated a cycle for about 25 minutes: steady for about 2 seconds, then a slow blink, then a fast blink. After about 25 minutes it stayed steady.
  • When the Connection light is steady and the ONT is connected to the Experia Box v10, the modem's Internet light blinks quite fast, and its Service light is orange. There is no internet.
  • I also tried another router, but I am not sure if I set it up correctly: PPPoE on VLAN 6, priority 7.
Is there a way to get an engineer appointment earlier, this week? From next week onward I am not available.
Thank you very much for your time and help.
  • nov 8, 2026 12:25 a.m. UTC
You have 14 days to cancel the new subscripton. This time goes in when the order is completed. The order will complete when you or the engineer succesfully install the experiabox. You will get an email with the message that the order has been completed.
So as long as you dit not have received this mail the copper connection wil remain operational and your 14 days have not started yet. This means that even when the engineer comes in december you still have the full 14 days to change your mind.
Hello ​@cornball1698, i can confirm what ​@Sacratus1977 is saying. As long as the fiber connection is not working, your copper connection will remain operational. Have you recieved an e-mail with a date? From that date shouls your fiber connection be active.
  • nov 12, 2026 3:20 p.m. UTC
  • nov 13, 2026 9:22 a.m. UTC
Update: connecting my own router directly to the ONT (without the Experia Box)
Now that the line works, I connected my own router directly to the ONT, without the Experia Box. Maybe this is useful for others who want to do the same.
My setup
  • KPN fiber 500/500, with the black Nokia ONT supplied by KPN.
  • Router: GL.iNet GL-MT6000 with OpenWrt 25.12.
  • The ONT Ethernet port is connected to the router's WAN port (2.5G).
  • Internet only. I do not use KPN TV or the KPN phone line, so these are not covered here.
What KPN needs
  • PPPoE on VLAN 6.
  • KPN does not check the username and password. I used internet/internet.
  • MTU: set the WAN port and the VLAN to 1508 and PPPoE to 1500 (baby jumbo frames, RFC 4638). Then you get a full 1500 MTU and no fragmentation.
  • IPv6: you get a /48 prefix through DHCPv6 over the PPPoE connection.
OpenWrt config (/etc/config/network)
config device
option name 'eth1'
option mtu '1508'
config device
option name 'eth1.6'
option mtu '1508'
config interface 'wan'
option device 'eth1.6'
option proto 'pppoe'
option username 'internet'
option password 'internet'
option mtu '1500'
option ipv6 '1'
config interface 'wan6'
option proto 'dhcpv6'
option device '@wan'
option reqaddress 'try'
option reqprefix 'auto'
eth1 is the WAN port on this router. On other routers the name can be different.
Results
  • PPPoE connected in a few seconds.
  • Speed: about 495 Mbit/s down and 505–555 Mbit/s up. This is the same as with the Experia Box, so the box was not a bottleneck.
  • Ping is about 1.5 ms lower without the box.
Tips
  • First test the line with the Experia Box. If the box also cannot connect, the problem is not in your router, and only KPN can fix it. In my case, KPN's own box also could not connect until KPN fixed something on their side.
  • After a restart, my ONT needed about 25 minutes before its connection LED was steady. Before that, the LED went through a cycle of on, slow blink and fast blink. Wait for a steady LED before you test.
  • Some posts say that the PPPoE packets must have priority 7 (802.1p). The Experia Box does this, but my router connected without it.
  • nov 13, 2026 5:01 p.m. UTC
My setup
What KPN needs
  • PPPoE on VLAN 6.
config device
option name 'eth1'
option mtu '1508'
config device
option mtu '1508'
option mtu '1500'
option ipv6 '1'
Results
Tips
Meer info ook te vinden op: https://www.kpn.com/service/eigen-apparatuur
