Fritzbox7490: Verbinding lijkt wel jojo en veel errors.
  • December 4, 2021
  • 9 reacties
  • 310 keer bekeken
DutchFlash
Helper
De laatste dagen lijkt mijn verbinding wel een jojo en zie ook errors is mijn log.
Heb een Fritzbox 7490.
Wat is er aan de hand met mijn internet ?
04.12.21 03:45:56 IPv6 prefix obtained successfully. New prefix: 2a02:a464:****::/48
04.12.21 03:45:56 IPv6 internet connection established successfully. IP address: 2a02:a464:e4d1:*****fee1:96d9
04.12.21 03:45:23 Could not establish IPv6 internet connection: No response from DHCPv6 server (SOL).
04.12.21 03:45:06 IPv6 internet connection error: DHCPv6 error because of 8 (NoAddrsAvail)
04.12.21 03:44:46 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
04.12.21 03:44:43 DSL is available (DSL synchronized with 28453/7294 kbit/s).
04.12.21 03:44:16 DSL synchronization starting (training).
04.12.21 03:44:11 Timeout during PPP negotiation.
04.12.21 03:44:11 IPv6 internet connection was cleared; prefix no longer valid.
04.12.21 03:44:11 Internet connection cleared.
04.12.21 03:44:07 DSL not responding (no DSL synchronization).
03.12.21 11:44:29 IPv6 prefix obtained successfully. New prefix: 2a02:a464:****:/48
03.12.21 11:44:29 IPv6 internet connection established successfully. IP address: 2a02:a464:e4d1::*****:fee1:96d9
03.12.21 11:43:56 Could not establish IPv6 internet connection: No response from DHCPv6 server (SOL).
03.12.21 11:43:39 IPv6 internet connection error: DHCPv6 error because of 8 (NoAddrsAvail)
03.12.21 11:43:20 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
03.12.21 11:43:09 Internet connection cleared.
01.12.21 17:20:41 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
01.12.21 17:20:30 Timeout during PPP negotiation.
01.12.21 17:20:30 Internet connection cleared.
01.12.21 03:38:47 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
01.12.21 03:38:43 DSL is available (DSL synchronized with 28639/7264 kbit/s).
01.12.21 03:38:16 DSL synchronization starting (training).
01.12.21 03:38:11 Timeout during PPP negotiation.
01.12.21 03:38:11 Internet connection cleared.
01.12.21 03:38:07 DSL not responding (no DSL synchronization).
24.11.21 03:39:44 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
24.11.21 03:39:33 PPPoE error: Timeout.
24.11.21 03:39:27 DSL is available (DSL synchronized with 30340/7192 kbit/s).
24.11.21 03:39:01 DSL synchronization starting (training). [2 messages since 24.11.21 03:38:17]
24.11.21 03:38:12 Timeout during PPP negotiation.
24.11.21 03:38:12 Internet connection cleared.
24.11.21 03:38:07 DSL not responding (no DSL synchronization).
16.11.21 10:29:12 Internet connection established successfully. IP address: **.***.97.3, DNS server: 195.121.1.34 and 195.121.1.66, gateway: 195.190.228.172, broadband PoP: 195.190.228.172
16.11.21 10:29:08 DSL is available (DSL synchronized with 28279/7317 kbit/s).
16.11.21 10:28:41 DSL synchronization starting (training).
Beste antwoord door DutchFlash
Hoi Bram_, Sinds 5 dec. geen rare meldingen meer in de FritzBox. Dus alles doet het weer goed.
9 reacties
  • December 4, 2021
Ik vind het zeer frappant dat de onderbreking op 24-11 en 1-12 tot op de seconde op het gelijke tijdstip plaatsvinden en die op 4-12 precies 6 minuten later.
Je zou bijna denken dat dit een centraal aangestuurde geautomatiseerde reset is.
DutchFlash
Helper
  • December 4, 2021
Ben benieuwd wat KPN hier op gaat antwoorden:wink:
Bram van KPN
Forum|alt.badge.img+17
  • December 6, 2021
Hi @DutchFlash! Ik heb het met de gegevens in je profiel ingekeken en vanuit onze kant is in ieder geval geen aansturing gedaan om de verbinding te verbreken. Wel kan ik de verbrekingen zien in mijn systeem. Op de verbrekingen na is de verbinding verder ook stabiel. Er is dus geen zichtbare ruis of iets dergelijks. Weet je zo of je ook verbrekende verbindingen hebt op het moment dat je een Experiabox hebt aangesloten?
DutchFlash
Helper
  • December 7, 2021
Hoi Bram, Heb weer een melding in mijn modem log.
Ik ga niet (sorry)de experiabox aansluiten, blijf mijn Fritzbox gebruiken. Ik heb niet het vermoeden dat het aan de Fritzbox ligt.Ik kijk het nog een tijdje aan, hoe het verloopt.
Bram van KPN
  • December 8, 2021
Helemaal goed @DutchFlash! Het is overigens niet zo dat ik je vraag om weer op de Experiabox over te gaan. Het is uiteraard puur om uit te sluiten dat het aan de verbinding ligt. Mocht je toch kans zien dit te testen, erg graag! :relaxed:
DutchFlash
Helper
  • December 9, 2021
Hoi Bram_, Ik weet wat je bedoelde met die vraag. :wink: Tot nu toe geen errors meer in mijn log.
Bram van KPN
  • December 17, 2021
Hi @DutchFlash! We zijn ondertussen iets meer dan een week verder. Is het goed nieuws in de vorm van het foutloos werken van je FRITZ!Box?
DutchFlash
Helper
  • December 17, 2021
Bram van KPN
  • December 17, 2021
Gelukkig! In dat geval sluit ik het topic voor je. Blij dat alles weer werkt zoals het hoort te werken. :relaxed:
