Geen wifi op de tweede verdieping
  • December 14, 2019
  • 34 keer bekeken
Katarzyna Wojciechowska
Nieuwkomer
Hi, I bought the internet from KPN. I have not WiFi on 2nd floor.  I try to order monteur but I can't. I have no idea what is wrong with it.
Hi Katarzyna! If the WiFi isn't working I'd advise you to use our wifi tuner. It will analyse your WiFi connection and improve the settings. If that doesn't result in a better connection, it will show an end result which should solve the issues you're experiencing. The tuner is in Dutch, so if you’re experiencing difficulties with knowing what to enter when it's asking for information, don't hesitate to let me know! I'm happy to help.
2 reacties
Sanne van KPN
  • December 15, 2019
Sanne van KPN
I haven't heard back from you, so I hope the problem is solved! If it isn't, don't hesitate to reply to this message. :slight_smile:
