Haal snelheid niet na wijziging
  • October 22, 2019
  • 20 reacties
  • 187 keer bekeken
Hi people,
I switched to hussel 200 but my download speed is still around 100Mb/s. Do I need a different modem?
Kind Regards,
Eugen
*Admin: response split off, own topic created.
Beste antwoord door jack_martynov
Hi Alex, I called Friday and got assigned to V+ connection switch. It should happen at the start of the next month.
20 reacties
  • October 23, 2019
Do you have a glasfiber connection or a VDSL connection?
When you have VDSL, what does fourstack tell you about the maximum possible speed on your address?
I have VDSL and I see next
Technologie
Internet Snelheid
Koper/DSL
213 Mbit/s
Bonded Koper/DSL
  • October 23, 2019
Is your Experia Box connected to the "ISRA" point with a Y cable? (One plug in the Expedia Box and two in the ISRA?
No! I have just one-to-one cabel. Where can I get Y cable?
  • October 23, 2019
Just to avoid any mistakes, could you please provide a real screenshot of the fourstack page. Please remove te postalcode and housenumber before you make the screenshot.
Which Experia Box do you have?
I have ZTE Experiabox v10
And here is screenshot that you asked
  • October 24, 2019
OK,  forget the Y cable as this is a VVDSL connection.
The Experia Box V10 is absolutely capable to handle 200Mbps so no other Experia Box is needed.
I assume you measure that speed from a PC that is connected via a network cable and not via wifi.
I have one of the best WiFi from a couple of years ago. Do you think it is a wifi setting?
  • October 24, 2019
Please measure the speed on a PC that is connected through a network cable.
What speed do you measure?
That is impossible for now - I have mac and I don’t have an adapter for the network cable.
I just use speedtest.net in the browser.
  • October 24, 2019
In order to determine if it is the line to Internet that is still limited to 100Mbps you must measure the speed through a wired PC.
Also use this speedtest tool or use the server from RoutIT B.V. in Ede within speedtest.net.
Only when your MAC is connected through 5GHz wifi (not 2.4GHz) and the distance to the Experia Box is small I would expect speeds that are equal to the speed on a wired PC.
  • October 24, 2019
Can you also make a screenshot of the DSL status page on your Experia Box where the attainable and actual rates are shown?
What is the value for the actual rate?
it was rebooted 31 hours ago - exactly when I switched to the new tariff.
  • October 24, 2019
Ok, now it's clear, the actual rate is just above 100Mbps.
That means your line is currently not capable of higher speeds.
I hope a moderator from KPN will respond shortly as this is NOT good.
When fourstack says that a speed above 200Mbps is possible then the actual speed should at least be near that value.
Thank you! Appreciate your help and I will just call KPN service to speedup the process.
Forum|alt.badge.img+28
Hi jack, welcome on our board.
Did you manage to solve this by calling us? If not, please fill in your info here. Let me know when it's done. :)
  • October 26, 2019
Glad to hear. Reach out if you need anything.
Have a great day!
