Heavy incoming packetloss, when pinging from outside; outgoing is ok
  • November 13, 2025
  • 11 reacties
  • 131 keer bekeken
I see a lot of incoming packet loss, when pinging my KPN Glasvezel Connection from Outside (reproducible from different locations):
601 packets transmitted, 332 received, 44.7587% packet loss, time 606759ms
rtt min/avg/max/mdev = 14.741/15.755/32.145/1.856 ms
Ā Outgoing Ping is ok. Nearly no packet loss. Traffic that is originated from inside (Download, streaming etc) is ok. But when I for example VPN into my Home net from outside, it is nearly impossible to connect.Ā
My modem is a XGS-PON and a Fritzbox 7590 behind. Fritzbox configuration is pretty standard.
No relevant errors recorded in Fritzbox.
Ā
11 reacties
WMG-N
Forum|alt.badge.img+12
  • November 13, 2025
​@Volker ButtersteinĀ
Using a VPN is a good recipe for getting banned by KPN. Can you exempt the KPN emailadresses from going through the VPN ?
I don’t use KPN email at all. The VPN from outside is for accessing my home assistant (Linux Server for home automation). So there is no reason from KPN to ban me. That's IMO a normal and legit use of my Internet connection.
fixnix
  • November 13, 2025
I wonder why that is?
Ā
Forum|alt.badge.img+28
Hi ​@Volker Butterstein, welcome on our board.Ā
It’s important to determine whether there is actual packet loss and where exactly it occurs. I recommend running a test using PingPlotter to identify where the loss happens and especially at which hop. Could you try this?
Could you try this?
Hi Alex,
this is a Screenshot of Ping Plotter from a foreign Network (External at my neighbor) to my current IP of my Fritzbox:
No Network Device between Fritzbox and XGS-PON.
The Routing and packet los the other way (from my Network to the foreign network a my neighbor) look normal and has a different routing:
I hope this gives you some insights.
I appreciate your help! Thanks
Volker
fixnix
  • November 16, 2025
Hi Volker,
Try if you can do a traceroute. I find it more clearly.
You can make a screenshot, without show your or your neighboor’s public IP adres.
Ā
Traceroute from my Network to neighbor(direction outside):
1Ā  <internal IP of my fritzbox> Ā 3.288 msĀ  3.194 msĀ  6.806 ms
2 Ā <external IP of neigbor> Ā 8.350 msĀ  6.234 msĀ  6.965 ms
Traceroute from neighbor network to my IP (direction to my network):
1Ā  * <internal IP of neighbors net>Ā  5.897 msĀ  6.168 ms
2Ā  195-190-228-142.fixed.kpn.net (195.190.228.142)Ā  13.684 msĀ  36.021 ms *
3Ā  * * *
4Ā  195-190-228-142.fixed.kpn.net (195.190.228.142)Ā  70.514 msĀ  64.594 msĀ  12.875 ms
5Ā  * <my external IP>Ā  21.004 ms !XĀ  20.005 ms !X
This traceroute last some seconds and will not work every time.
Thanks for help
VolkerĀ
Ā
fixnix
  • November 16, 2025
The "21.004 ms !X" and "20.005 ms !X" near your external IP suggest the packets are being administratively prohibited or filtered at your firewall or network edge, leading to failed traceroute completion sometimes.
Also:
Due to firewall configurations etcĀ your traceroute results and their occasional failures are consistent with network devices on either side of your boundary (firewalls, routers) filtering or blocking ICMP/traceroute packets. This is normal behavior to enhance security but can cause traceroute to show incomplete paths or timeouts.
Does your firewall accept ICMP packages?
Ā
On my side there is a simple fritzbox 7590 supplied by KPN. No special configuration on the outside interface. No ICMP blocking. Roughly every second or third packet gets a response.Ā
Today I had a not very satisfying call with KPN Support about the topic seen above.
They tell me that a connection from outside directly to my KPN provided Fritzbox is NOT a guaranteed service.
A simple ping from outside (a KPN provided DSL Internet connection) to my Fritzbox results in 30 to 60 percent packet loss.
A connection from inside my network to the Outside seems to work without packet loss.
They checked the connection on the physical layer and that seemed to be ok. But I think my problems are one or two layers above.
So I am stuck with a connection that is not useable from outside to my home automation components.
Anybody an idea, what is possibly wrong on my side? I just want to have a reliable connection to the IP of my Fritzbox.Ā
In my opinion this is a standard feature of every Internet connection I have ever had.
Solved!
Changed the Internet Provider away from KPN. All Problems gone.
No Packet loss incoming any more.
Thanks for not helping me KPN.
