Help with connection, adapter for 4-pin connection
  • okt 6, 2024 11:50 p.m. UTC
  • 1 reactie
  • 83 keer bekeken
Hello,
I moved to a new address and have ordered a new KPN connection to this address.
 The house has a 4 pin connector.
Would I need a special connector/cable to start using the internet?
Regards,
Somobrata
Beste antwoord door Anonymous
Hello @sballabh
If you have a wallsocket like this:
You'll need this connector:
You can call KPN customer service 0800-0402 during office hours to request one or go to a DIY shop and buy one (Say to the computer you want to speak to an employee).
In Dutch it’s called a ‘varkenssnuit’ connector.
What exactly is specified on the order confirmation?
If you have a pair bonding connection then the four pin socket should be replaced for a new connection which support pair bonding, for that you also should call the KPN customer service, tell them you have the wrong socket and ask for a mechanic to replace it.
1 reactie
  • okt 7, 2024 12:33 a.m. UTC
Hello @sballabh
