Hi WiFi disconnecting problem
  • mei 5, 2019 12:55 p.m. UTC
  • 236 keer bekeken
RaduH95
Nieuwkomer
Hi , can you help me please with my wireless connecting , every 5-10 minutes always reconnecting and it’s very annoying , I saw on forum someone had this problem and solve this , I’m using the Experia box v10a
first day was very ok but after that disconnecting every time
thank you
Beste antwoord door RaduH95
I restarted the modem and now it’s working I hope won’t happen again
Forum|alt.badge.img+28
  • mei 6, 2019 5:50 p.m. UTC
Hi Radu, welcome on our board.
Are you experiencing this on all devices with WiFi or only one? Dit you restart the Experiabox? Did you also delete/forget the network on your device and reconnect again after that?
Would you also please fill in your postal code and house number here?
  • mei 6, 2019 6:34 p.m. UTC
The best solution is to swap the V10A for a V10 (without A).
RaduH95
Nieuwkomer
  • mei 7, 2019 2:29 a.m. UTC
