How can I change WiFi to 2.4 GHz
  • October 1, 2024
  • 163 keer bekeken
How can I change Wi-fi to 2.4 ghz as I have few devices which can run only on 2.4 ghz
Beste antwoord door Noordzee
Hello @PK Goel ,
This is the complete instruction:
  • October 1, 2024
Hello @PK Goel what brand and type of modem/router do yo have form KPN?
  • October 1, 2024
@JanD , it’s KPN box 12b black
  • October 1, 2024
Hello @PK Goel , you can then log in to the router and click on 'extra WiFi' in the WiFi installations and activate the 2.4 band for your applications.Success.
  • October 1, 2024
thanks for your support.
I was trying to add extra Wi-fi but couldn’t add it.
Do you have any instructions? I can see extra Wi-fi but nothing to add
  • October 1, 2024
Hello @PK Goel ,
Maja van KPN
  • October 4, 2024
Hi @PK Goel,
I see our community has come to your help, did you manage to set up a 2.4Ghz network now? Or do you need any further assistance?Â
