How can I track my recently placed order?
  • June 19, 2023
  • 680 keer bekeken
Hi,
I have made an order for internet but I can’t track it’s status as I haven’t received a client number?
Can anyone advise on what I can do?
Beste antwoord door GerritS76
@Andyec93 What sort of connection did you order?
Usually it takes at least 2 weeks before a connection will be activated - unless additional work is required.
When you read the e-mail with subject ‘Bedankt voor uw bestelling’, it usually shows a date under "Startdatum …………...”the shown date is the date you prefered, this might change and will be mentioned in a second e-mail.
The best and fastest way to get an update on your order is to call KPN Customer Service on 0800-0402. Customer Services can be reached from Monday till Friday from 8:00 AM till 6PM (18:00), or Saturdays from 8 AM till 5PM (17:00).
  • June 19, 2023
Usually the Track and Trace is sent as soon as the item has been shipped but it also depends what sort of order you have placed.
With a mobile subscription, the SIM card is sent via regular mail without Track and Trace, when ordering a mobile phone, the Track and Trace code is sent when the phone is out for delivery.
If you have ordered an internet subscription, the same applies as with a mobile phone, a Track and Trace will be sent when the items are sent.
The modem etc. as usually sent one week before the date the connection will be active.
  • June 19, 2023
Thanks for the quick response Gerrit.
It is an internet subscription. It was ordered last week 14th June and when I ordered it, the 23rd of June this Friday was shown as the start date. However it doesn’t mention this starting date on the contract or other document. I have an order number but no client number so no way of tracking it and I haven’t received any info since regarding a delivery or starting date. Have you any recommendations on what I should do as I am under pressure to have it set up for working remotely as soon as possible.
Thank you,
Andrew
  • June 19, 2023
  • June 19, 2023
Hi Gerrrit,
I checked my email as you suggested and found “You have asked us to start your subscription on June 23, 2023.” There hasn’t been any email regarding a start date since then. Perhaps calling is best. Thanks for your help!
Andy
