Impossible to connect PS4 code ce-32895-7
  • jul 15, 2019 4:58 p.m. UTC
  • 1237 keer bekeken
Zeosophie
Nieuwkomer
Bonjour,
Nou si ne pouvons pas connecter le Wi-Fi à notre ps4.
Le code erreur est ce-32895-7.
Merci de vos retours
Sophie
Hi Zeosophie, welcome on our board.
I don't speak french so I hope you understand English. Does you internet connection work fine on other devices? Phone, laptop, tablet etc. I've found the following regarding this error code: https://www.errorsolutions.tech/error/ps4-error-ce-32895-7/
I hope it helps.
2 reacties
Forum|alt.badge.img+28
  • jul 16, 2019 4:26 p.m. UTC
I hope it helps.
Jack Adision
Nieuwkomer
  • jul 9, 2021 8:00 a.m. UTC
The PS4 error CE-32895-7 occurs due to the network issues or any changes imposed by your internet service provider, failed pending firmware update. Luckily there are fixes that works for you to fix the error. Try the tricks like:
  • Reset the router
  • Update the PS4 firmware from Safe Mode
  • Rebuild the database
Hope these fixes will works for you to fix PS4 error CE-32895-7.
