Internet falling down temporarily for a minute
  • January 30, 2023
  • 88 keer bekeken
Internet falling down for like 1 minute and then coming back, what should I do? Someone can help me?
2023-01-30 03:12:46 PPP(eth_route):ppp0 down for reason is Peer not responding
2023-01-30 03:12:46 PPP(eth_route):ppp0 down for reason is LCP down
2023-01-30 03:12:50 PPP(eth_voip):ppp1 down for reason is Peer not responding
2023-01-30 03:12:50 PPP(eth_voip):ppp1 down for reason is LCP down
2023-01-30 03:12:52 PPP(eth_route):Connection terminated
2023-01-30 03:12:53 PPP(eth_route):Sent PADT to d8:49:0b:b5:0d:df, SessionID is 42169
2023-01-30 03:12:56 PPP(eth_route):start Discovery
2023-01-30 03:12:56 PPP(eth_route):send PADI and wait for PADO 1 sec
2023-01-30 03:12:56 PPP(eth_route):recv PADO
2023-01-30 03:12:56 PPP(eth_route):send PADR and wait for PADS 5 sec
2023-01-30 03:12:56 PPP(eth_route):recv PADS,SessionID is 36887
2023-01-30 03:12:56 PPP(eth_route):Starting negotiation on ppp0
2023-01-30 03:12:56 PPP(eth_voip):Connection terminated
2023-01-30 03:12:56 PPP(eth_route):PAP authentication succeeded
2023-01-30 03:12:56 PPP(eth_route):set local/remote IP: 77.174.238.245/195.190.228.25; dns: 195.121.1.34/195.121.1.66 on ppp0
2023-01-30 03:12:56 TR069:Start to create a new session.
2023-01-30 03:12:56 PPP(eth_voip):Sent PADT to d8:49:0b:b5:0d:df, SessionID is 34790
2023-01-30 03:12:57 TR069:Sending inform 4 VALUE CHANGE
2023-01-30 03:12:57 TR069:Session create success.
2023-01-30 03:12:59 PPP(eth_voip):start Discovery
2023-01-30 03:13:00 PPP(eth_voip):send PADI and wait for PADO 1 sec
2023-01-30 03:13:00 PPP(eth_voip):recv PADO
2023-01-30 03:13:00 PPP(eth_voip):send PADR and wait for PADS 5 sec
2023-01-30 03:13:00 PPP(eth_voip):recv PADS,SessionID is 52127
2023-01-30 03:13:00 PPP(eth_voip):Starting negotiation on ppp1
2023-01-30 03:13:00 PPP(eth_voip):PAP authentication succeeded
Thanks @linaaadd, I see a note that they have tried to call you, but couldn't reach you. I found out there was a different phone number registered than you had filled in your forum profile, so I contacted a colleague and asked fot help. He just reached out to me te inform me he successfully contacted you on the right phone number and that a mechanic is scheduled this afternoon 😊
Maja van KPN
  • February 1, 2023
Hi @linaaadd, I'm sorry to hear your facing these downfalls in your connection 🙁
Can you please update your profiel and give me a heads up if you’ve done so? I'd like to run a diagnostic on your line, to see if I can find any errors!
  • February 1, 2023
Hello @Maja_ , I did update my profile.
I already called few times to kpn service and everyone tried to do something, but nobody can, I already can see reason into service log, I request mechanic two times, they said that he will call me , but he didn’t yet, so if u will help me I'll be very grateful
Maja van KPN
  • February 2, 2023
  • February 2, 2023
Yeah, mechanic coming today, thank you for helping :)
Maja van KPN
  • February 2, 2023
You're welcome! 😊
