Internet light is flashing green after installation KPN Box 12
  • November 4, 2021
  • 155 keer bekeken
I have followed the online instructions to install the modem, and have waited for roughly an hour. The internet light is still blinking green. Is this because of an installation error, error on the infrastructure or on the connection itself from KPN?
Admin: Editted title to make it easier to find
Hi @MaasFran . Welcome to the forum.
Did you manage to resolve this issue? If not the best course of action is to call 0800 0402.
I can help you to but then I wil need your information. Can you fill out your profile for me and give me a sign?
2 reacties
  • November 6, 2021
  • November 6, 2021
Hello Erwin_
It has been solved thank you, obe of your technicians found a fault on the line and corrected it.
All the best and kind regards
