Internet speed problem
  • March 23, 2019
  • 9 reacties
  • 459 keer bekeken
Arisho
Deelnemer
dear ladies and gentlemen
since 2 days my internet is very slow, it only gives me 0.06 mb, i have tried with 2 smartphones but it was the same, i am live in germany
bestgr
Beste antwoord door Joran
Please see Marina's reply in Ahmadhijazi's topic here: Het internet was snel en heel slecht en traag en nutteloos | KPN Community. The higher speeds were a problem on our end. Unfortunately this is the intended speed for the unlimited bundle. For higher speeds you can consider a 1GB or 100MB bundle, depending on how much data you'd like to use. Prepaid bundels: extra voordelig bellen, sms'en en internetten | KPN
9 reacties
Arisho
Deelnemer
  • March 23, 2019
Regards
Joran
Forum|alt.badge.img+28
  • March 24, 2019
Hi Arisho, sorry to hear you're having problems with the internet connection! What network are you connected to? Does it help to select a different provider manually?
Arisho
Deelnemer
  • March 24, 2019
I’ve connected with Telekom and also with Vodavone
but it was also the same . From 21st,March it was happened.
Arisho
Deelnemer
  • March 24, 2019
I’ve connected with Telekom and also with Vodafone but it was the same. From 21st March my internet is very slow
Joran
  • March 25, 2019
What kind of speeds did you get before? The Speedtest screenshot is normal if you have the "Onbeperkt Online" or "Zorgeloos Online" bundle. Due to an error these bundles might have had much highers speeds in the past, that 'issue' was recently resolved.
Arisho
Deelnemer
  • March 25, 2019
I have Zorgeloos, but it was already so fast. From 21st march(4 days ago) my internet was so good and fast.
now it opens nothing. Only my messenger works
  • March 25, 2019
Yes ,the internet zorgeloos now it open nothing
Ver very bad
Joran
  • March 26, 2019
Arisho
Deelnemer
  • March 26, 2019
Thank you so much
but what can I do with 1GB, if I watch one Video, 1GB will be finished so fast
I think, we should now throw away our Simcard.
Thank you so much for one year service with KPN.
