Internet speed upgrade
  • mrt 18, 2020 12:35 p.m. UTC
  • 107 keer bekeken
I want to know the current internet speed in my package and how i can upgrade the speed.
Beste antwoord door Susan_
Hi @jwhengst, welcome to our KPN Forum and thanks for you message!
What is possible within your subscription is stated in your contract. Your speed is also in MijnKPN. Most of the time this is around 50Mbit/s (standard). But sometimes it's possible to upgrade this. It is first of all useful to see what speed is possible at your address. At Fourstack you can see what is currently possible at your address. You are often connected to the best available, but it may be that it is upgraded later and you are not yet connected to the best available. I'll take a look at the systems you're connected to. Can you fill in your Forum profile, with at least your name, zip code + house number and customer number?
I would like to hear from you!
2 reacties
Susan_
  • mrt 20, 2020 9:09 a.m. UTC
Susan_
  • mrt 25, 2020 10:04 a.m. UTC
@jwhengst, unfortunately I haven't heard from you anymore. Can I still help you with this?
