Invoice older than 12 months
  • jan 6, 2021 1:58 p.m. UTC
  • 93 keer bekeken
Hello,
I need access to the invoice that contains the period covering January 1st 2020.
Since this falls in the invoice of December 2019 it is no longer available in my invoices.
Can you please share this with me?
Thank you.
Kind regards,
Marta Cristovao
Beste antwoord door Marta Cristovao
Thank you very much @Rutger_ .
I've received the invoice in good order, it's exactly what I needed.
Rutger van KPN
@Marta Cristovao Welcome to our forum.
I would like to check what I can do for you. Could you fill in your forumprofile with your zip code, customer number and the last 3 digits of your bank account.
Then I will check if I can send you the invoice! :)
Hi @Rutger_ , thank for your reply.
I have updated the forum profile with the requested information.
To make it clear: I need the invoice of December 2019, which should cover the period from December 11 till January 10.
Thank you.
Rutger van KPN
@Marta Cristovao Thank you for filling in your profile I send the invoice you were asking for by mail!
  • jan 17, 2021 3:06 p.m. UTC
