KPN fibre optic connection with TP-link Deco, is this pppoe or dynamic?
  • nov 29, 2025 10:30 p.m. UTC
  • 8 reacties
  • 228 keer bekeken
I have KPN fibre optic connection how I setup using tplink mesh deco. What will be internet connection type pppoe or dynamic?
Beste antwoord door TDN
​@Soniya Not Advandced by Internet but first click on More, then on Advanced, then IPTV/VLAN, then Mode=Custom, then activate Internet VLAN, then VLAN-ID and VLAN-Priority.
8 reacties
bnh
Forum|alt.badge.img+12
  • nov 29, 2025 11:28 p.m. UTC
Hi ​@Soniya!
PPPoE
VLAN 6
Login name: internet
Password: internet
  • nov 30, 2025 8:03 a.m. UTC
Even after entering username and password as internet it is still the same does not connect. Previously we were using default kpn box so does kpn need to register new Mac address of deco?
bnh
  • nov 30, 2025 8:23 a.m. UTC
Are you connected through the ONT or directly to the fiber?
  • nov 30, 2025 8:37 a.m. UTC
Hi ​@bnh
Thank you for your reply.
It beleive it is directly to fiber. I have attached screenshot for your reference
bnh
  • nov 30, 2025 8:57 a.m. UTC
Hi ​@bnh
Sure, happy to help!
This is your ONT, so you don’t need separate registration for your router, which is great. Could you post a screenshot of your router’s internet settings?
  • nov 30, 2025 9:03 a.m. UTC
You need to use VLAN-ID=6 on WAN to get working internet
More → Advanced → IPTV/VLAN
  • nov 30, 2025 12:53 p.m. UTC
I am not able to find blanket mode please find attached screenshot
  • nov 30, 2025 1:09 p.m. UTC
  • nov 30, 2025 2:43 p.m. UTC
I would like to thank you for your help. It did work.Â
