KPN fibre optic connection with TP-link Deco, is this pppoe or dynamic?
  • November 29, 2025
  • 8 reacties
  • 200 keer bekeken
I have KPN fibre optic connection how I setup using tplink mesh deco. What will be internet connection type pppoe or dynamic?
Beste antwoord door TDN
​@Soniya Not Advandced by Internet but first click on More, then on Advanced, then IPTV/VLAN, then Mode=Custom, then activate Internet VLAN, then VLAN-ID and VLAN-Priority.
8 reacties
bnh
Forum|alt.badge.img+12
  • November 29, 2025
Hi ​@Soniya!
PPPoE
VLAN 6
Login name: internet
Password: internet
  • November 30, 2025
Even after entering username and password as internet it is still the same does not connect. Previously we were using default kpn box so does kpn need to register new Mac address of deco?
bnh
  • November 30, 2025
Are you connected through the ONT or directly to the fiber?
  • November 30, 2025
Hi ​@bnh
Thank you for your reply.
It beleive it is directly to fiber. I have attached screenshot for your reference
bnh
  • November 30, 2025
Hi ​@bnh
Sure, happy to help!
This is your ONT, so you don’t need separate registration for your router, which is great. Could you post a screenshot of your router’s internet settings?
  • November 30, 2025
You need to use VLAN-ID=6 on WAN to get working internet
More → Advanced → IPTV/VLAN
  • November 30, 2025
I am not able to find blanket mode please find attached screenshot
  • November 30, 2025
  • November 30, 2025
I would like to thank you for your help. It did work.Â
