Missing parts for installation fiber connection
  • nov 27, 2024 11:17 p.m. UTC
  • 10 reacties
  • 135 keer bekeken
My appartment was just connected to KPN fiberglass and I’m switching from other provider to KPN.
So I got the package with Experia Box modem BUT I couldnt coonnect it via Ethernet cable as I have only white box on the wall with name: Glasvezelaansluitpunt... That’s it.
So it seems that I’m missing some part, right? How I can get it?
Without it modem is just useless.
So stupid!
Hi ​@EvgenyI,
First of all, welcome! I agree with Huistijger; the easiest option is to schedule an installation technician. You can easily do this online on our website.
10 reacties
  • nov 28, 2024 12:15 a.m. UTC
Hello ​@EvgenyI
That’s weird, normally you'll get a glassfiber modem with the installation package unless a technician is necessary anyway.
If there isn't an installation technician planned then call KPN customer service 0800-0402 (mo to fr 8AM - 6PM, sa 8AM - 5PM) and say to the computer you want to speak to an employee.
They can send you the glassfiber modem or make an appointment for an installation technician.
huistijger
  • nov 28, 2024 6:18 a.m. UTC
Hi ​@EvgenyI
You can also make a calling-appointment yourself
KPN will then call you immediately, or at a time that suits you.
scroll down until you see: maak een belafspraak
They are available 24/7 for urgent malfunctions
  • nov 28, 2024 10:41 a.m. UTC
Thank you for your feedback!
I have just called the support and they told me that my new contract with KPN in their internal system is for KPN “copper” which it seems I do not have in the house...at least I do not see any connection...and they can’t send me the new package for fiber ( which I already have in the appartment)
How it is possible ? It is ridiculous
may be you can give me advise with whom I could contact in support to solve this problem on KPN side
Dank je wel!
  • nov 28, 2024 10:50 a.m. UTC
It can be possible if it isn't a KPN network fiber connection point.
There are several providers in the Netherlands and KPN doesn’t want to use fiber from other providers.
Can you place a picture of the Glasvezelaansluitpunt?
huistijger
  • nov 28, 2024 10:55 a.m. UTC
Enter your zip code and house number on the following link:
https://netwerk.kpn.com
Then you can see whether you have fiber or not.
  • nov 28, 2024 12:37 p.m. UTC
I think this box indicate that I have fiber glass from KPN in the appartment…
But KPN support say they couldn’t organize connection to it …  because in their system I have to be connected via copper which I do nit have...what a nonsense!
  • nov 28, 2024 2:04 p.m. UTC
The only reason I can think of is that the connection isn't ready yet, it was recently installed?
Probably the other end of the fiber still needs to be connected in the district exchange.
  • nov 29, 2024 8:25 a.m. UTC
According to the KPN site my appartment is connected to the fiber glass...so it meens that it should work...
huistijger
  • nov 29, 2024 8:29 a.m. UTC
Hoi ​@EvgenyI
You can order a free technician who will ensure that your connection is ready bij calling 0800 0402
Forum|alt.badge.img+28
  • dec 3, 2024 8:51 a.m. UTC
Hi ​@EvgenyI,
