Modem password incorrect
  • August 19, 2021
  • 406 keer bekeken
Hello Every one
I’m trying to login into the https://mijnmodem.kpn/2.0/gui/#/login/
The modem is new and i did not changed anything so far. Just trying to login with the password i saw behind the modem, also scanned the QR code to be sure is the correct password and still not working. Any idea? thanks in advance.
Beste antwoord door NHendriks
Was the modem installed by a KPN mechanic? Then it might be possible that the password was changed. Best is to do a full paperclip-reset by holding a paperclip in the small hole above the power-button until all the lights go out on the Box12. Then the password of the scanned QR-code should work.
If it doesn't, make sure it doesn't add a space or something at the end because that will result in a wrong password entry as well.
2 reacties
NHendriks
Forum|alt.badge.img+12
  • August 19, 2021
  • August 28, 2021
Yes that works perfectly!!! thanks so much for your support! :grin:
